Any suggestions where to obtain this? or if it is obtainable.
KM6030 OSX 10.10 print driver
Re: KM6030 OSX 10.10 print driver
Thanks for that..I thought somewhere someone might have had some special editions.
I am in for a Olivetti D800 or UTAX CD1080 or KM8030 and I am able to print from OSX 10.7 with this lovely conflict(see picture)
What infuriates me is that Printing from Win7 or Win8 is OK. i.e. Why bother doing Win drivers or adding them in library and not doing the same for OSX. And even with 10.7 which meant to be supported is giving headaches
Can anyone direct me what could have gone wrong. It actually picks up through Bonjour the printer driver but it doesn't autoselect the Booklet and Hole punch. Had to manually select that and Hole Punch works and so does staple. Booklet however ...getting this message when selected. Tried PDF and Word and Excel and PP and all the same. Any hints?
Screen Shot 2015-04-01 at 23.40.21.jpgComment
Try installing the driver using the PPD file, sometimes listed under Linux print drivers. As long as you are not using Accounting on machine it should work. Download and unzip the file first and point the installer to the correct PPD file for the machine.Comment
Appreciate your help.
Sent from my iDon't believe in marketing device using TapatalkComment
