KM 5035 C0640
  • CSC80
    • Jun 2025
    [Error Code] KM 5035 C0640
    I have a KM 5035 the print button light blinks and when I press the print mode has message format error hard disk and I also get another message
    hard disk error press go code: 1. After restarting the copier I got a C0640 and when the copier goes into energy saver mode you can hear the hard drive
    still spinning does not stop, copy mode works no problem making copies.
  • subaro
    • Oct 2010
    • 1274
    Re: KM 5035 C0640
    1087 1087 to get into service mode
    u24 format hard drive.
    If same replace hard drive or remove hard drive and check hard drive integrity on a computer with usb to ide hard drive interface device. Also check the hdd cables connections.
