3050ci cloning to 3051ci ?? SETUP Tool ?
  • bronco31
    • Aug 2009
    • 174
    ive got a 900 Job Accounting list i cant seem to move over to a new 3051ci...
    917 from the 3050 gives 3 files...
    then i open them in Setup tool.. then i get angry and hold in lots of high blood pressure.. #$#@Kyocera!
    from reading up i gather im to "open" or "prepare" both? main files? one by one? then set the destination machine to a 3051ci?
    the Setup Tool manual says theres a dependency, "files cannot be opened by themselves"
  • CWP
    • Jun 2013
    • 168
    Re: 3050ci cloning to 3051ci ?? SETUP Tool ?
    Use KM Net Viewer, export and import of is much easier. You will need to add both devices to the accounting view and then use the set multiple accounting devices option.
    • Kyo fan
      • Dec 2013
      • 368
      When exporting with U917 don't just select accounting, cause there will be some dependencies missed. Instead, select everything, and than open it with Setup tool and it will work.
      • Tonerkiller
        • Oct 2012
        • 669
        You would think so. I do not know why Kyocera makes it so difficult. You have to use KM-Net viewer.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          there's actually 5 files no?
          AC1/2, AD1/2, OT1
          and still wont work on job accounting, LOL.
          Idling colour developers are not healthy developers.
          • bronco31
            • Aug 2009
            • 174
            OK.. played with it abit in the office...i think this is the way to best clone machines between older and newer models..
            Net Viewer is a little dicey when it comes to choosing destination vs source machine though.. sigh..
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              there used to be KM net for accounting, but it died. i wish Kyocera keep that project updated.
