am having intermitted jams when doing duplex copying,appparently this machine is straight from the box, event log shows j4011 as the cause which translates to reg sensor problem.have done latest firmware update,to version (2015.01.16) checked the bulletin duplex roller pad modification,which is already done from factory,swopped reg clutch and duplex clutch ,with hope of isolating one of the clutches but still getting the same jam code.
have also checked on the connection to reg sensor, duplex sensor ,and the wiring connections to the conveying unit but all seems Ok. surprisingly at some occassions the machine can do up to 20 duplex copies without a single jam, then suddenly it can happen.
any ideas or suggestions are welcome
