Kyocera FS-C5350DN Call Service 6400: 0013804
  • tibbs
    • Aug 2008
    • 223
    Hi, am not a Kyocera tech and we have none close by, but I have customer with a FS-C5350DN with an error code that says Call service :
    6400: 0013804. any assistance will be much appreciated.
  • darry1322
    • Oct 2010
    • 817
    Re: Kyocera FS-C5350DN Call Service 6400: 0013804
    The 6400 part of the code indicates a zero cross error which points toward the power supply.
    Most of these I have dealt with on copiers were resettable in service mode.
    I see no service mode setting for that in the printer manual.
    Try to unplug the printer and then see if it resets after being plugged back into the outlet.
    The 0013804 part is the page count.
    • copymech
      • Sep 2011
      • 196
      10871087 enters service mode. 163 resets fuser errors. If code returns then replace fuser.
      • darry1322
        • Oct 2010
        • 817
        C5350DN is a printer with no keypad.
        • laitang
          • Nov 2012
          • 627
          6400: Zero cross signal error
          Detail: The zero cross signal does not reach the engine PWB for specified time.
          Causes:
          - Defective harness between power source PWB (YC103) and engine PWB (YC19), or improper connector insertion.
          - Defective power source PWB.
          Check procedures:
          - Reinsert the connector. Also check for continuity within the connector harness. If none, remedy or replace the harness.
          - Replace the power source PWB
          • kjg
            • Mar 2009
            • 111
            It should be resettable as was mentioned by power cycling the machine. Check for equipment with high power draw on the same circuit as the printer such as a soda machine or a microwave. I see these codes all the time in the winter here because people will have a small space heater on the same plug as the printer. If the voltage on the neutral line is too large the machine will never get a good zero cross and thus throw the code.
