Kyocera and Wireless Printing
  • daveyball
    • May 2009
    • 314
    If you put the IB51 Wireless NIC in a new Taskalfa range machine, can you print over the LAN with the hard wired option, and then over a separate ADSL network with the wireless option.
    Cheers
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera and Wireless Printing
    Two network interfaces means you can connect and work on two different networks. Just keep in mind that you can only print on the optional IB51, cause sadly it's not made to scan through it.
    • daveyball
      • May 2009
      • 314
      Cheers Kyo Fan.
      • jmaister
        certified scrub
        • Aug 2010
        • 754
        devices like WES610n is a much cheaper choice.
        Idling colour developers are not healthy developers.
        • bronco31
          • Aug 2009
          • 174
          yet im able to scan to email thru it....but just a scheduled "maintainence" or "event" report.
          (this is thru the IB51 web interface)
          bummer... as it does have the capability to do SMTP.. just not able to connect to the Address Book in the main body.. so an enduser can scan-to-email !
          not ready for primetime!
          • CWP
            • Jun 2013
            • 164
            You can scan through the IB-51 or the standard NIC on the machine, just not both. It has to be set to scan to the IB-51 if desired under the system/network settings.
