kyocera km 1500 c6050 resety fuser
  • Dogtech
    • Jul 2025
    [Error Code] kyocera km 1500 c6050 resety fuser
    to long ago since repairing km1500 how to get into service mode and reset fuser error c6050
  • laitang
    • Nov 2012
    • 627
    • copydocinc
      • Mar 2015
      • 263
      Re: kyocera km 1500 c6050 resety fuser
      After opening the front and top covers, press the stop/clear key, start key and then the left copy exposure adj. key in that order and hold them down together, to get into sim. mode. press the clear key, then press 163 for sim 163, then press start, CLE appears on the screen, then press start again to clear the code. To get out of sim. press the stop/clear key then 001 then start. If code doesn't go away, you haven't fixed the problem causing the error yet. maybe needs thermistor, thermal fuse or lamp. hope this helps.
