for this FS6525 do you have to buy the primary feed unit or are there rollers available (feed, pickup, seperation). Looked in the manual can't find the rollers seperatly. THANKS
kyocera primary feed unit fs6525
Re: kyocera primary feed unit fs6525
FS-6525 also
Model 3500i, 3050ci-3550ci, 3501i, 3051ci-3551ci, ALSO Item 205c, 255c, 255, 305 Main Feed Part Number Pulley Pickup Assy 302HN06080 Pulley Feed Assy 302F906230 Retard Roller Assy 302F909171 -
For FS-6525MFP, Kyocera wants you to change the entire primary feed. It comes as: PRIMARY FEED UNIT (302K394480), as can be seen in the parts list:
It also comes like that in the Maintenance Kit. The above mentioned parts will work too. I'ts up to you if you want to save some $, or some time.Comment
