Muratec MF c2700 image issues
  • copiertec
    • Jan 2016
    • 2206
    I am having these sporadic issues with this MFP. It seems if I readjust the flat cables attached to the laser LED's the problem stops for a few weeks. Should I replace the flat cables? Or is there another issue? Its an MFX-C2700.
  • faxgoddess
    • Apr 2012
    • 70
    Re: Muratec MF c2700 image issues
    Is the machine sitting on a flat surface? You shouldn't have to adjust the print-head cables constantly.
    If you make a copy and pull the transfer belt out before it images to the paper are you getting the same image written to the belt? Does it happen only on black, or is it any color?
    Meg
    "The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather in a lack of will."
    --Vince Lombardi
    • JR2ALTA
      • Feb 2010
      • 2033
      I've seen lots of weird laser/ribbon issues but never really seen that dragging effect caused by one.
      And if I'm not mistaken, a laser issue would be left-to right not top-to-bottom
      Looks like something isn't turning. Drum, drum drive, transfer belt...
      • copiertec
        • Jan 2016
        • 2206
        It has happened so far on yellow and black images only, but not simultaneously, at first it was just the yellow, then received a call a week later and it was happening on just the black. I had the customer make sure the flat cable were flat and not kinked in any way and also made sure the cable was seated properly in the LED. I'm also pretty sure it's sitting level, but I didn't put a level to it, I haven't heard back from them since.
        I was thinking the same thing JR2ALTA but am not 100% percent sure because it is only happening to just a single color even on color prints, so far; but will definitely look for something in these areas... I'm kinda puzzled.
        • faxgoddess
          • Apr 2012
          • 70
          I'd kind of be careful with having the customer look at the cables. I've seen people inadvertently hit one of the print heads when swapping supplies (but the cover likely wasn't open all the way) and damage the board.
          --Vince Lombardi
