Muratec MFX 2570 0B system error... 20050
  • Obaseki Best
    • Feb 2019
    • 7
    [Error Code] Muratec MFX 2570 0B system error... 20050
    Hi, please my Muratec MFX 2570 on start up is showing 0B system error... 20050
    How can i solve this problem?
    Re: Muratec MFX 2570 0B system error... 20050
    is this a personal unit?
    are you a tech by trade?
    • Obaseki Best
      • Feb 2019
      • 7
      Its my personal copier
        Hire a tech
        • Obaseki Best
          • Feb 2019
          • 7
          Hire a tech
          I want to know what can be done about it..
          Just tell me
          • ntbann
            • Jan 2012
            • 627
            Just tell me
            He told you. Hire a tech!
            • Obaseki Best
              • Feb 2019
              • 7
              I did.. The rech said he needs to change the circuit board...
              Is that whats really the cause?
              • dsmith46
                • Oct 2016
                • 81
                Wow, such nice "techs" on this board. Ridiculous. 0B refers to a fan problem. It could be just a fan that needs replaced, or it could be the main board. Hope this is somewhat more helpful.
                Good luck!
                  no what is ridiculous is people come here.. post a Q with NO information to help us... they don't have manuals .. have no real tech knowledge but then EXPECT us to solve their problems....
                  and then there are techs that give out info to: enter service mode...change settings ( not knowing if they did it right ) and then blast others for not wanting to help someone that CLEARLY doesn't need to stick their fingers in the unit...
                  over my 31+ years have seen more DAMAGE to a unit because some numb nuts THINKS doing reair work is soooo easy.
                  • dsmith46
                    • Oct 2016
                    • 81
                    I do understand, to a point, what you mean. But, you don't have to be so rude about it. I try to help whomever needs it, regardless. Just my two cents. To each their own. Have a good day.
                    • Obaseki Best
                      • Feb 2019
                      • 7
                      Good luck!
                      I cleared all ram in my muratec 2570 and it automatically shutdown.. After it came up it started showing "close flashing cover" (i.e the front cover). The surprising thing was that the flashing cover was properly close and it was still showing it..
                      Pls what can i do about this?
                        hey numbnuts... HOW was I rude?
                        All I did was tell him to " Hire A Tech " (as did another tech) .. in FACT you were there rude one telling us that we weren't will to help.
                        You know as well as I do... SOME people should NEVER put a screwdriver in their hand ( some are techs here )
                        People are always wanting someone to do their work for them.. no matter the position in that
                        company.
                        So now you have a recourse of being a snowflake.. you can now downgrade my rep power.. fine.. you have been blocked by me but I just had to open this post to see your reply.. and yes IT was just the way I thought it would read.
                          thank you Sir.. you have just NOW proven my point to DSmith... bwahahahaha
                          • Obaseki Best
                            • Feb 2019
                            • 7
                            Please tell me the cause of this and what the tech should do to fix it
                            • Obaseki Best
                              • Feb 2019
                              • 7
                              Am from Nigeria, the tech here are not too familiar with how to fix this muratec products.. Pls tell me the solution to the problems
