Oki C5650
  • Orion2010
    • Jun 2015
    • 176
    Oki C5650
    hello all ,
    i have oki C5650 i change drum and if i orint color are OK oki c5650.jpg but if i print BLACK oki cc5650.jpg any ide please ? toner life 90 % and belt life 16 %
    thanks
  • subaro
    • Oct 2010
    • 1274
    Re: Oki C5650
    get the manual or go to okidata website and see the installation procedure for the drum. seems like the drum is not installed properly and the drum is not pulling toner of the dev. If it was working before you install new drum, then definitely recheck the drum install.
    • Orion2010
      • Jun 2015
      • 176
      Re: Oki C5650
      The problem it was before I change the drum and it is the same again. ?
      • fishleg
        • Mar 2009
        • 426
        Re: Oki C5650
        Led problem normally just take ribbon off and reinsert. What ever you do make sure machine is off. You can also swap the leds round if its not that its the board the ribbon plugs into.
        Sent from my D6603 using Tapatalk
