Service Manual SC322: 1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated. - Possible causes - Poor connection between the laser synchronization detector board and the LD unit. Laser synchronization detector board out of position Laser synchronization detector board defective LD unit defective
[S C 3 22 1st laser sync error] - TSB # 10 - raise the right hand side of the LD unit assembly appox 1 mm Perform laser pitch adjustment.
