CX2731 service call 134
  • richs
    • Nov 2008
    • 266
    On these models if the customer puts the drum unit in wrong and displaces one of the LED cables you could get an error code.The most common is 134.The fuse on the CU board goes.Has anyone been replacing these fuses.Does anyone have a part number or place they can be purchased.They are surfaced mounted and would require some investment in equipment to attempted.I would like to try it but need the fuse to start the process.
  • onetek
    • 318
    Re: CX2731 service call 134
    Time for you to find fuse F501 (behind top right corner) and put a trace of solder on it. (its the one protecting the led heads).Your choice of risking one day to fry a led head or to fork out good money to buy a CLP4 board...
