Oce 9400 Scan to file issue.
  • bernyb
    • 42
    I was recently on a little sales call for new clients. I stopped into a printer I hadn't seen before because they had a wide format sign. They have an Oce 9400 and although I have worked on this machine for a few years I am in the infantile stage when it comes to the software stuff. Anyway the guy described a problem he was having when he wanted to scan to file to make a CD for his customer and he can't do it without the machine making a printed copy also. I had no answer for him and would like to play the hero here if you know what I mean. Anyone have an answer for me on which area to change to get to just scan to file. They are running Windows 98.
  • bubbabear
    • Jul 2008
    • 23
    OCE 9400 question
    Does anybody know where I can get a used controller for an OCE 9400?
    Bubba Bear is off to the maul.
    • jasonsp6
      bernyb,
      There is a option in the Oce settings editor called "Check Print". Turn it off and it will scan without plotting a copy simultaneously.
      • turkeyfoot
        • Oct 2008
        • 66
        You'll have to have a Scan to File license. Check the configuration report and it should be indicated, if not punt....
        • ndershams
          I have a sulution for your printer.
          r u install the scan station first,
          r u conect to machin monitor.
          is the machin write ready to scan on the plotter
          if not install the aspe file for your computer and the scan will work on windows xp without any problem
          contact me if y need any help or any sw
          nadershams@hotmail.com
          • Mike Harden
            control yes
            contact mike at 360 513 5847 he has a warehouse full of Oce parts tell him 6172 sent ya
            • Mike Harden
              Controller Available
              YES
              Originally posted by Mike Harden
              Yes! Contact Mike at 360 513 5847 he has a warehouse full of Oce parts tell him 6172 sent ya
              • azzajil
                • 12
                TDS400 Firmware download
                Hi,
                I'm trying to download firmware to OCE TDS 400
                I really appreciate any help
                Thanks in advance.
                • jzheld
                  • Sep 2010
                  • 162
                  Does anybody knows where to download scan station?
