riso drum board
  • edpianix
    • 30
    [Error Code] riso drum board
    riso ez 220 got an error P96-569
    Got this error after we replace the ink cartrage.
    we found out that this is drum board.
    we call the supplier of the machine, even the one who supply the ink and master.
    Do we have any solution for this.
    may God bless Us.
  • Iowatech
    Not a service manager
    • 3930
    Re: riso drum board
    I'd try resetting the machine first. Turn off the machine and then turn on the machine while holding down the "Reset" key. Keep holding down the "Reset" key for 5-10 seconds (it is easier for me to release the "Reset" key when the initializing motor sounds get quieter, in case that would be easier for you too).
    Hopefully that will take care of the error code, as replacing the drum board is a chore, and I don't have my manuals on hand right now.
    There's even more Riso techs here:
    http://www.copytechnet.com/forums/digital-duplicators/
    so you might post your question there to see if any of them have other suggestions.
    • edpianix
      • 30
      Re: riso drum board
      may God bless Us.
      this the board. any body can help us repair this board.
      • edpianix
        • 30
        Re: riso drum board
        anybody has experience this this kind of duplicator copier. or anybody has parts code of this so we can ask the supplier. thanks
        may God richly bless you
        • hader1967
          • Feb 2015
          • 7
          Re: riso drum board
          Print drum color information
          Error Type :T96_569 [Data not input]
          Either the Print drum color information or Ink category information is still not input
          Test Mode Procedures
          PRINT POSITION
          Press the two print position keys simultaneously and turn ON the machine power.
          Operating Procedure
          Test mode numbers can be entered (selected) via [Key entry] or [Menu selection].
          a) Key entry procedure
          (1) In standby mode, enter the number of the test mode to be run using the numeric keys. If you make a mistake during entry, you can perform entry once again by pressing the [C] key.
          (2) Press the [START] key to initiate Test mode operations.
          (3) Press the [STOP] or [START] key to end Test mode and return to standby or operation standby modes.
          * In data setting mode, after setting the new data, press the [START] key to confirm the modified data and return to standby mode. Instead, if the [STOP] key is pressed, the newly input data is cancelled and the existing data setting remains.
          Inter test mode Number :1214 (Drum Color Code Entry)
          Sets the print drum color information on the EEPROM of the Drum PCB.
          Setting:
          0: Not Specified <default>
          1: Black
          2: Blue
          3: Medium Blue
          4: Red
          5: Bright Red
          6: Riso Federal Blue
          7: Purple
          8: Riso Marine Red
          9: Burgundy
          10: Green
          11: Teal
          12: Brown
          13: Yellow
          14: Light Grey
          5: Grey
          16: Fluorescence Pink
          17: Fluorescence Orange
          18: Orange
          19: Flat Gold
          20: Hunter Green
          21: Crimson
          30: Custom
          31: Order (with specified paper)
          32: Order (without specified paper)
          63: Any Color
          with tanks
