HP color laser jet 3600n broken piece
  • nhyrum
    • May 2016
    • 55
    I've been at this customers for over an hour and a half. Found this plastic piece on the right(power switch) side and can't find where it belongs.
    Sent from my SM-G920V using Tapatalk
  • Elmtech
    • Nov 2013
    • 155
    Re: HP color laser jet 3600n broken piece
    Right hand side cartridge lock lever slide. Long white plastic part that moves all the rhs cartridge locks when you pull the transfer belt down or up.
    • nhyrum
      • May 2016
      • 55
      That would make sense. The belt doesn't close right anymore. You wouldn't happen to have a part number? So I can look it up
      • Elmtech
        • Nov 2013
        • 155
        RC1-6643-000
        Should be it. Make sure you realign the main drive before reinstallation. Do not and you will get noisy running or errors.
        • nhyrum
          • May 2016
          • 55
          Thanks. I'll see if I can't find the service manual here
          • nhyrum
            • May 2016
            • 55
            I can't seem to find the procedure for aligning the main drive unit in the SM I have.
            • nhyrum
              • May 2016
              • 55
              once you get the new part in place ( check the other side also ) you will notice you have to have the front cover down and the gear train has arrows and holes on the gears.. get the arrows lined up with the holes on ALL gears in the set. it can be a pain and may take a few tries to get them set right.
              Yeah. It was fun to get it all back together and aligned. Don't usually work on HP's but they're basically a Canon
              • nhyrum
                • May 2016
                • 55
                OK guys, sorry to revive this dead thread, but just had the same thing happen on a Canon lbp 5360. Essentially the same machine with a different badge.
                Does anyone know if I use the same part number? The HP number is in the format of a Canon number.
                  Check to make sure the other lock levers aren't busted too! I have had several like this... there could be springs missing... pull both side covers to make sure you don't have the same issue on the left side. I have the service manual if you need it.
                  philb@steppservicesinc.com
                  • nhyrum
                    • May 2016
                    • 55
                    That's a good idea.
                    I have access to Canon's e support so I can get my own manual. I was out on the road so I wanted to check here to see if anyone knew if the numbers were the same, and they are
