Ok, I have seen this issue a few times in different fiery, but this customer is.... more difficult. When you go to print your jobs, you select printer properties to go into the fiery option, bastard takes 30-45 sec to pull up. Even if you try to go into different options, ie finishing,layout etc, the driver will crash (not responding message) or hang for 15 or so sec. Hook up crossover with my laptop, same thing. Driver loaded both locally, and from \\192.168...... selecting the print que. If you send job to hold que on command workstation, job can be manipulated fine. Tried multiple drivers from one stop, and directly from fiery. Disabled two way communication. Loading patches tomorrow, but wanted to see if anyone has seen this.
As I said, I usally tell the customer to manipulate in cw, which responds appropriately, but this guy is old school.
