OKI C830 not recognising magenta toner
  • aAandy
    • Apr 2012
    • 370
    #16
    Re: OKI C830 not recognising magenta toner
    did you put a new drum in it.. the fuse was blown but not recorded in the board
    did you call tech support? they would have told you this... and where did you get the board from? thru oki ours only $230 and it take about 1/2hr - 40 mins to do
    i keep in-line fuses on hand & reset the M drum unit - no data transfer was required, though i'll have to setup network addy's etc
    everything's expensive in Australia, could have got it cheaper from the U.S. but client didn't want to wait 3 weeks
    i think the board did fix the problem though, as now the fault follows the magenta drum unit around - i suspect the M toner RFID chip got damaged, so i'm fitting a new OEM Magenta toner today (they cost me $232.00 wholesale)
    will keep you posted
    • aAandy
      • Apr 2012
      • 370
      #17
      the new magenta toner sorted it, i have ordered a toner chip so the old (but still full) magenta toner can be used
      so a BIG thank you Phil, couldn't have done it without you
        hey Brother.. been working on this crap for too long not to have picked up a few tricks.
        • richs
          • Nov 2008
          • 265
          #19
          New Toner fixed it.I did say try a new toner....from another lot.I have run into a few toner problems.
          • spree
            • Jun 2012
            • 211
            #20
            Hello, I have problems, but with drum only. The machine OKI C830 says: End of life imaging unit CYAN, replace it.
            Customer bought genuine drum unit CYAN, but still this message.
            Than I bought OEM imaging unit CYAN, but still this message.
            In service mode I tried to change consumable from STOP to countinuos. It print one to five pages after power on, but after that still this message (replace imaging unit CYAN) and new message (replace imaging unit MAGENTA).
            Motors are turning, clutches are working, contacts are cleaned.
            Maybe the "flag" in drum windows is closed??? I forgot about it! Is there the "flag" in drum?
            And what to do, when the flag will be O.K. - change mainboard (formatter)?
            • spree
              • Jun 2012
              • 211
              #21
              As I saw, there is no "flag" in drum unit, sorry about that.
              Any ideas?
