Oce vp6160/vp6200/6250
  • Casimir
    • Aug 2025
    We are trying to set up some applications on the above machine.
    It looks like trays setting is unviersal. This means that when you set it up it impacts all the jobs in the queue.
    We tried Postscript and PCL and both gives us the same time of problem. the postscript header can only control one media type and PCL is globally impacted. Has anyone found a way around that?
  • Peter_Oce
    Casimir,
    The Oce VP6000 concept is that you assign a specific media type to a tray (or multiple trays). The system will map the media that are requested by your job (programmed through driver or workflow software) automatically on a tray that has the specific media available. So media programming in the job and the set-up of the machine are independent and flexible. There are not enough details in your description to see what your problem is exactly, and I will send you a message with contact details of a specialist that will support you.
    Regards, Peter
