Dell B5465nf Testing and Installing an Operation Panel
  • rbazan
    • Dec 2013
    • 70
    [Electrical] Dell B5465nf Testing and Installing an Operation Panel
    I want to replace the Operation Panel on the Dell B5645nf with another unit that is working.
    I am using a Lexmark 812 manual and found a *disturbing/confusing note on the disassembly:
    Control panel removal (Lexmark MX81x)
    , control panel board, or controller board, replace
    only one component at a time. Replace the required component and perform a POR before replacing a second
    component. If this procedure is not followed, the printer will be rendered inoperable. Never replace both the control
    panel and the controller board without a POR after installing each one or the printer will be rendered inoperable.
    *Never install or remove these components as a method of troubleshootingWhen a component has been installed in a machine and has been powered up in
    normal user mode, it cannot be used in another machine
    ; it must be returned to the manufacturer. The machine
    must be powered up in Diagnostic mode or the controller board, control panel boards, or control panel will become
    locked.
    Can I test Operation panel on another machine in safety mode?
