Hi
We have a IBM/Lexmark T522 printer with the M35 Scanner, Document feeder, fax unit. It all works except direct faxing from the workstations.
Also did a fax transmission test, from the M35, which reported Transmission Level -20.3dBm. Does anyone know how to (if possible) boost the output?
- Is it a case of emailing to faxnumber@fax or similar to send a fax?
- Is there client software for this?
