BROTHER Fuser temp
  • enricocopyline
    • Jun 2018
    • 122
    BROTHER Fuser temp
    Good evening to everyone, in the brother of the 5700 6600 series it is possible to increase the melting temperature?
    To avoid not fixing the toner where there is so much humidity?
    Re: BROTHER Fuser temp
    are you sure it's humidity?
    how many pages on the fuser... they fail before the 100k cycle
    most times fuser temp is controlled by the media weight properties
    • enricocopyline
      • Jun 2018
      • 122
      the toner is original I tried to change the fuser but I did not solve it.
      the copier is almost new
      paper is normal 80g
        paper is normal 80g
        "almost new" doesn't tell me shit.. if you want help provide the information requested.
        • enricocopyline
          • Jun 2018
          • 122
          About 11,000 copies
            About 11,000 copies
            if less than 1 yr old... call Brother
            • enricocopyline
              • Jun 2018
              • 122
              No is not under warranty
                OFW.. REPLACE THE FUSER
                • enricocopyline
                  • Jun 2018
                  • 122
                  Already changed
                  • Demon33
                    • Jan 2019
                    • 38
                    There is no adjustment for temp in service mode , try to select thick paper &/or quiet mode .
                    Also check if the firmware is up to date.
                    Was the fuser an original ?
                    I changed a lot of fuser on those for blurry/light print quality , but not for toner fixing problem.
                    Most of the time it's compatible toner in that case.
                      paper is normal 80g
                      you say " the toner is original I tried to change the fuser but I did not solve it."
                      you DO mean OEM REAL Brother Toner.. Please keep in mind MOST time those carts that come with the printer PRIME the dev units and print.. those AREN'T those carts that CAME with the printer are they?
                      IF not are they TRUE OEM's or EBay's?
                        I have changed a few for not Bonding toner to the page.. but RARE..
                        I saw your post..went back read OP " the toner is original I tried to change the fuser but I did not solve it."
                        That got me to ponder..11,000 total on unit.. original toners? not at 11k.. must have made toner change..question oem..drums should go 2 toner change
