MX-2600N freezes menu within a few minutes of startup
  • Forzagp
    • Feb 2019
    • 13
    Hi,
    Please let me know if you have any suggestions on what might cause this behavior.
    If possible, please share the latest firmware with me so that I can try to update the
    firmware to see if this will help.
    Re: MX-2600N freezes menu within a few minutes of startup
    Originally posted by Forzagp
    Hi, Please let me know if you have any suggestions on what might cause this behavior.
    If possible, please share the latest firmware with me so that I can try to update the firmware to see if this will help. Thanks
    you could start by making sure the cables to the OP panel are connected properly.... then yes firmware
    • mansart
      • 852
      Is this connected to a network?
      If so does the lock up occur when network cable is disconnected?
      If no, under "network settings" "Protocol settings" make sure "RARP" is disabled.
      • Forzagp
        • Feb 2019
        • 13
        The cables all seem to be seated. I disconnected and reseated them after blowing them out.
        If you have the latest firmware, I would appreciate a copy.
        Also, the machine is no longer booting up after connecting it to the network. Leds D10 and D13 flash at a constant rates and the fans spin up but the display screen never lights up. I do get the green standby light on the control panel. The new behavior started after shutting the machine down and connecting it to the network.
        Please let me know if you have any other thoughts and whether the machine would accept an emergency usb firmware update if the screen never lights up. Thanks for your help.
        • Forzagp
          • Feb 2019
          • 13
          The machine was disconnected from the network. I went to connect it to the network to remotely administer the machine and now the machine does not light up the display. The fans spin up but no display.
          Please let me know your thoughts. Thanks for your help.
          • mansart
            • 852
            does the machine boot if network cable is unplugged?
            • Forzagp
              • Feb 2019
              • 13
              After I moved the machine to plug in to the network the machine no longer shows anything on the display regardless of the whether the network cable is plugged in.
              I tested both sides of capacitors on the left side of the mfp board and there is a short to ground somewhere. I will try a thermal imager to see if I can find it but I would appreciate direction on the likely potential culprit.
              Any ideas why the machine would intermittently have this issue and then short to ground?
              Thanks for all the help.
