OKI MC861+ Fatal Error 142
  • jonbonse
    • Jun 2009
    • 737
    I have error 142 on a MC861+ which is an ID up/Down error.
    I can see the drums moving up and down so I suspect the ID up/down sensor.
    I am struggling to find this in the parts guide and wondered if anyone here would know if it is part of another assembly..
  • onetek
    • 318
    Re: OKI MC861+ Fatal Error 142
    If I remember , its part of the board on the left side. Did you check the motor in test mode, with and without drums? Couple of times I had this code on that copier, it was due to binding mechanism. Cleaning and greasing was ok.
      is the ITB seated properly? I have seen it where it was not seated correctly and caused this error.
      • jonbonse
        • Jun 2009
        • 737
        Thanks!
        I didn’t check the motor because I could see the drums lifting when I fooled the top cover.
        Is it a strip down to gain access to the lift mechanism?
        I had them change the cyan drum and it worked for a couple of days....
        Also is the board on the left side when looking at the printer from the front?
        thanks
        • jonbonse
          • Jun 2009
          • 737
          Thanks for your response.
          Yes I did reseat the ITB and it is in as it should.
          • onetek
            • 318
            Yes, this board is on the left side , standing in front of copier.
