HP 4730 MFP reset
  • bcopier2815
    • Oct 2015
    • 42
    HP 4730 MFP reset
    I put a new transfer unit in but status still says 15% left. I have been looking online and get conflicting results. Does it reset via a fuse or is there a reset I can perform?
    Mike
    Re: HP 4730 MFP reset
    Mike
    HP CLJ 4700 / CP4005 / 4730MFP / CM4730MFP / CP4025 / CP4525 / CM4540MFP / M651 / M680MFP / M855 / M880MFPThis series has the fuser and transfer belt designed to automatically reset the consumable counters Please Note: r part There is no way to reset either fuser or transfer count other than replacing the component Do not replace fuser and transfer belt at the same time. Replace one then perform POR
