risograph scanner not moving nor lighting
  • ritchie9
    [Misc] risograph scanner not moving nor lighting
    pls, what do you think i can do to a Risograph that cannot scan image because the scanner robot is not moving when it is on and the scanner light is not not on at all. thank you
    • 37572
    Re: risograph scanner not moving nor lighting
    You will get a lot more help if you learn to post in the correct Technical Forum. https://www.copytechnet.com/forums/digital-duplicators/
      and just MAYBE a MODEL NUMBER?
