oki c9800 black toner smear
  • Alastair38
    • Apr 2019
    • 24
    This is an old printer but its only done about 10,000 prints. There's a problem at the moment with black toner smear across the pages. I opened up the drum and toner can be seen stuck to the charger roller as in the pic. Is this most likely going to be fixed by a new image unit (before going and buying one), or is it more likely to be a voltage problem or alike?
    Re: oki c9800 black toner smear
    [ATTACH=CONFIG]44668[/ATTACH]
    well how many pages on drum?
    is it an OEM Genuine OKI drum?
    OEM Genuine Toner?
    if you can get the PCR out of the drum:
    1) clean with IPA and rinse in water.
    2) coat the roller w. NUFinish car polish.. let dry.. buff with soft lint free cloth
    3) inspect for more contamination or bumps/tears or other surface defects.
    4) if damaged (excluding buildup) toss the roller no good **unless you have another one drum is trash)
    5) if you still see toner build up repeat #2 until clean
    Replace and test. ** I have used this trick since the HP SX -> Ricoh Color series and ALL in between It has ALWAYS worked and even extended the life and gives IMHO a bolder darker (not too dark) print.**
    Security Check
    **i'm sure you can find it cheaper than the above.. just wanted to show bottle.**
    report back if any further issue
    I saw this alot with compatible toners
    it's best not to cheep out on supplies to avoid PQ/CQ probs and part wear will be increased
    • Alastair38
      • Apr 2019
      • 24
      OEM Genuine Toner?
      thanks, yes, all OEM parts. The drum has 10,000 pages on it but has been in there a long time. I'll have a go at taking it apart and cleaning it up, otherwise get a new unit.
        Try the trick I mentioned.
