HP M775 scanner error 30.01.44
  • rapo_tech
    • Feb 2019
    • 114
    [Error Code] HP M775 scanner error 30.01.44
    Hello
    I wiped the hard drive and installed newest firmware. Didn't help. It was 3 months ago.
    I said that the next move is to replace scanner board and then if that won't work i'll have to replace formatter.
    When the client got prices he refused to fix the machine but now (3 months later) he is considering it.
    Is it worth to check wiring between boards and if possible replace wirings?
    Or should I just start by replacing SCB and then formatter?
  • Zeldaman
    • Mar 2011
    • 946
    Re: HP M775 scanner error 30.01.44
    Hi there!
    Had this 2 times, and in both cases i had to change the scanner-assy.
    Greetings...
      • 22808
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      +1 had two with same problem ...same fix
      • rapo_tech
        • Feb 2019
        • 114
        So its not probably related to scanner control board or formatter?
        First choice should be scanner assembly?
