How to scan to dfs smb share on server 2019
  • eli
    Not a technician
    • Oct 2014
    • 40
    Hey Peolpe,
    Can anybody help? We have following Konica Minolta bizhub C224, Konica Minolta bizhub C454e, Konica Minolta MF335.
    Re: How to scan to dfs smb share on server 2019
    Originally posted by eli
    Hey Peolpe,
    do they allow SMB v2/3?
    have you installed proper firmware?
    what error are you getting?
    • eli
      Not a technician
      • Oct 2014
      • 40
      We are getting either server connection error (when using DFS share) or Logon error (when doing it to a regular share). It used to work with server 2016. Everything is configured correctly. Tried NTLMv1/v2/Kerberos or individually. Not sure about firmware, must be older. I can check and report back on firmware and smb v2/3 function. Machines are older. I'd really like to get at least the c454e and c224 working. MF335 can go without
      edit: forgot to add, i also made sure the time is correct and is syncing with domain controller which is important for kerberos/active directory authentication. the time was set incorrectly before when it was working with server 2016.
      • eli
        Not a technician
        • Oct 2014
        • 40
        C224:
        ROM Version
        MFP Card Version A1610Y0-F000-GB2-K5(00)
        MFP Controller BOOT Program A2X00Y0-1E00-G00-01(00)
        MFP Controller Linux Base Linux-2.6.26.8-rt16
        MFP Controller Kernel Program A2X00Y0-1C00-GC1-63
        MFP Controller SubSet A1610Y0-1F00-GA0-K1(00)
        MFP Controller A1610Y0-0100-GB2-K5(00)
        Operation Panel Message Data A5C10Y0-8100-GP1-K3
        Fax Board Controller1 A22M0Y0-4000-G00-10(00)
        Fax Board Controller2
        Fax Board Controller3
        Fax Board Controller4
        Scanner A2XK0Y0-0023-G00-07
        Printer A1610Y0-0050-G10-32
        ADF A3CF0Y0-0024-G00-12
        Finisher A2YV0Y0-0070-G00-01
        RU
        ZU
        Panel CPU A1610Y0-8900-G61-00
        DSC1
        DSC2
        Loadable Device Driver1
        Loadable Device Driver2
        SD
        Voice Data
        Movie Data
        Dictionary Data
        OCR Library
        Panel Sound Data
        MFP Controller Thread Image Parameter
        MFP Controller PIC Image Parameter
        MFP Controller System A1610Y0-1000-GB2-K5(00)
        MFP Controller Print Controller A1610Y0-3000-GH1-44
        MFP Controller Print Controller Font A1610Y0-3F00-G01-40
        MFP Controller Print Controller Demo Page A2XK0Y0-3E00-G00-81
        MFP Controller MIO A2XK0Y0-5000-G00-P1(00)
        MFP Controller PIC A2XK0Y0-8200-G00-11
        has smbv2 setting but on the server menu.
        c454e:
        ROM Version
        MFP Card Version A5C10Y0-F000-G00-K5(DB)
        MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
        MFP Controller Kernel Program A5C10Y0-1C00-G00-74
        MFP Controller SubSet A5C10Y0-1F00-G00-M0(00)
        MFP Controller A5C10Y0-0100-G00-K5(00)
        Operation Panel Message Data A5C10Y0-8100-G00-K3
        Engine Parameter A5C00Y0-0054-G00-00
        Engine BOOT A5C00Y0-0055-G00-00
        Scanner A5C10Y0-0023-G00-31
        Printer A5C00Y0-0050-G00-30
        ADF A3CE0Y0-0024-G00-10
        Finisher A3EP0Y0-0071-G00-18
        RU
        ZU
        Panel CPU A55V0Y0-8900-G60-00
        DSC1
        DSC2
        Loadable Device Driver1 A5C10Y0-A521-G00-01
        SD A3ER0Y0-0071-G00-08
        Voice Data
        Movie Data A5C10Y0-C000-G00-30
        Dictionary Data A5C10Y0-B100-G00-00
        OCR Library
        Panel Sound Data A5C10Y0-C200-G00-00
        MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
        MFP Controller PIC Image Parameter A5C10Y0-8A00-G00-01
        MFP Controller System A5C10Y0-1000-G00-K5(00)
        MFP Controller Print Controller A5C10Y0-3000-GH1-44
        MFP Controller Print Controller Font A5C10Y0-3F00-G01-40
        MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
        MFP Controller MIO A5C10Y0-5000-G00-M4(00)
        MFP Controller PIC A5C10Y0-8200-GC3-B1
          • 37628
          C224:
          ROM Version
          RU
          ZU
          DSC1
          DSC2
          SD
          Voice Data
          Movie Data
          Dictionary Data
          OCR Library
          Panel Sound Data
          c454e:
          ROM Version
          RU
          ZU
          DSC1
          DSC2
          Voice Data
          OCR Library
          All nice and pretty but none of that relates to firmware versions. What we need to see is SC 5990-005 Diagnostic Report printout.
          I saw something recently that Server 2016 authentication might fail unless you are using LDAP/NT.
          • eli
            Not a technician
            • Oct 2014
            • 40
            Sorry for asking a dumb question but how do i print that report?
            What do you mean by LDAP/NT? It actaully worked on server 2016 but fails on server 2019.
            • eli
              Not a technician
              • Oct 2014
              • 40
              It looks like i have to update firmware to support smb v2. Where can i download the firmware update if i'm not a technician? I have 5 machines to update. c554, c454, 363, c224, mf3335
              • tsbservice
                Field tech
                • 8064
                Sorry no SMBv2 FW support for above mentioned models. Time to upgrade print fleet or use other scan options.
                • eli
                  Not a technician
                  • Oct 2014
                  • 40
                  Are you sure? Konica minolta support said that firmware update will fix but I need to have a technician do it.
                  • eli
                    Not a technician
                    • Oct 2014
                    • 40
                    Is ftp a good alternative to smb scanning?
                      • 37628
                      That depends on how the customer's IT feels about ftp.
                      • eli
                        Not a technician
                        • Oct 2014
                        • 40
                        its for me, and i'm okay with it. I do have an issue with file permissions while using IIS FTP server.
                        We have many users and they often change passwords. Programming each user with their pass into the address book is not an option. I set up a one master account that also has permissions to scan to each user's folder. Is that a good solution? What do you guys suggest?
