Imagistics im3510 firmware
  • Paulm
    • 69
    Hi all, I am a Sharp tech and have been given the task to work on an Imagistics im3510. One of the techs here inadvertently flashed all the roms with sharp arm350 firmware and the pcu rom firmware is not compatable. Can anyone help me out with the rom data for this machine or direct me to a place to get it. Sharp firmware is readily available for me with constant upgrades so I assume this would be the same and should be somewhere just having a hard time locating. Any help is appreciated as I'm in dire straights.
    Paul
  • Marc J
    Firmware updates
    If you have access to the imagistics web site the firmware is available there. The site is webinfo.imagistics.com but can only be accessed thru a company web interface.
    • Paulm
      • 69
      Thanks for the info. Alas, I don't have that access. I was hoping that someone who did would D/L it and send it my way. But thanks again.
      Paul
      • kronical
        Kronic Copier Ninja
        • Nov 2009
        • 230
        Are you still in need of this firmware? Leave me your contact info and let me know
        • artfer
          • 24
          firmware im4511 needed too
          I"m looking for IM4511 firmware, someone can help me?
          artfer3@hotmail.com
          Tanks in advance.
          Artur Fernando
          • lildock08
            im5520 firmware
            I am working on a copier where I can't get the machine to talk to the SMTP. I believe this is because I am working with version 1.0 firmware. Does anyone know where I can get an updates version of the firmware for this machine?
            I am not having much luck
            Mary Ann
            • kronical
              Kronic Copier Ninja
              • Nov 2009
              • 230
              Mary Ann
              Firmware has little to do with this. Make sure you set your controller type and peripheral mode in service mode.
              Under Tech Rep Choice, Controller Set.
              If you have the Pi4700e controller, set your Peripheral Mode to '1' and reboot the machine. You should now be able to scan via SMTP.
              If you have the Pi5500 controller, set Peripheral Mode to '4'
