OKI C831 Cyan and Magenta not printing
  • Rich123
    • Jul 2015
    • 35
    Oki C831 not printing Magenta and Cyan. Black and Yellow print ok. Tried exchanging cyan and black printheads, but cyan still does not print. Any ideas? Thanks.
  • Blizzoo
    • Aug 2013
    • 607
    Re: OKI C831 Cyan and Magenta not printing
    Check the drum drive, both M and C are driven by 1 motor. You can swap the drum units just to test
    • Rich123
      • Jul 2015
      • 35
      Thanks for the reply. I did try changing the drum units, but when I swapped the black and cyan drum cartridges I got a sensor error. I did mark the gear that turns the drum, and it appears the drum gear is turning as the mark did move. Thanks again.
      • Quatro
        • Dec 2015
        • 78
        Is this working now ?
        Try to check the fuse at the maintenance board near the Print head cable
        • Rich123
          • Jul 2015
          • 35
          I have eliminated the printheads as a problem by swapping the printheads. I took black printhead which was working and swapped it with cyan. Still had same problem. I looked at the maintenance board, but found no fuse. Thanks for the reply. Any ideas are welcome.
          • Quatro
            • Dec 2015
            • 78
            hi,
            there is a lot of fuse in maintenance board check the fuse 15 (f15) near f12 and PH connector 3 at maintenance board it is open causing the cyan and magenta blank image.
