Oce plotwave 360 dead machine
  • Riviera
    • Sep 2016
    • 66
  • Quatro
    • Dec 2015
    • 78
    Re: Oce plotwave 360 dead machine
    Hi.
    I think you have software issue the windows embedded in the controller is crashed or the HDD
    To make it sure put the monitor in controller, you will see if the controller boots or no
    in this case you have to restore the controller and must have the license for that particular serial number.
    • Riviera
      • Sep 2016
      • 66
      Originally posted by Quatro
      Hi.
      • Quatro
        • Dec 2015
        • 78
        I think there is no issues on the power supply besides you mentioned that except the power button is blinking.
        In OCE PW and CW series the controllers boots up or initialize properly first before the engines powers up
        Why i ask you to put the monitor in that controller just to check if the controller is booting properly (same as windows)
        If you are familiar in controller location there is vga connector on it ( It is on left side under the toner dosage.)
        OCE has a windows embedded on it just make it sure that the controller is booting ang working properly before jumping to expensive part.
        How about the control panel is there some activity happening on it?
        Service manual of OCE is not available in any format (except for older models) that can be downloaded, this can be view via Phortos application
        • Riviera
          • Sep 2016
          • 66
          Nothing happening on control panel. It’s blank. When you power on machine the only sign of life is the soft switch blinking and you hear the relay above the power supply trigger then after 30 seconds sit triggers off. I’ve hade the controller out of machine .And I saw the VGA connector I’ll try that and see if that is ok. I did visually check out controller , looking for some life , no leds and hard drive never started up.
          • Quatro
            • Dec 2015
            • 78
            it was working before?
            • Riviera
              • Sep 2016
              • 66
              [QUOTE=Quatro;1647931]
              • Quatro
                • Dec 2015
                • 78
                [QUOTE=Riviera;1648178]sorry for disturbing you
                is this now working ?
                I just recovered my porthos and have now the TSM for PW360 what exactly you need a wiring diagram?
                • Riviera
                  • Sep 2016
                  • 66
                  [QUOTE=Quatro;1678549]
