Hi All,
just going to take a stab in the dark so if you have any knowledge could you please help me out.
I'm chasing an Oce program called Oce Scan Station v3.3 with Machine Monitor.
I've downloaded a copy from the Oce USA site however when it is loaded, the Machine Monitor GUI indicates a Oce 9800 instead of a Oce 9400 (which is what i need). I dont know if this is the reason why i cannot get my Oce Scanner and plotter to communicate with the software.
The PC is running XP Pro SP2. i've made sure i've got the ASPI files installed and ODBC v3.51 or higher.
so any indications of where i may be able to download the correct Machine Monitor application or what could be causing my problem would be great. thanks in advance.
kind Regards,
Steve
kind Regards,
Steve
