HP LJ E 87650 Freeze
  • Roger67
    • Nov 2013
    • 84
    Hello Folks,
    i have a E87650 who freezing in sometimes an then i get a 30.01.41 or an 30.01.57 code.
    30.01.41 means: Scanner communications Error
    30.01.57 means: Communication Issue with the PCIe Connection
    I changed the
    Main PCA
    the HDD`s ( both the HP and the Samsung Item )
    I installed the FW
    4.9.01
    4.11.02
    5.2
    Anyone has an Idea ?
    Roger
  • ninja_unmatched
    • Aug 2019
    • 14
    Re: HP LJ E 87650 Freeze
    By Main PCA what are you referring to? Give the part number....
    Sent from my SM-N986U using Tapatalk
    • Roger67
      • Nov 2013
      • 84
      Main PCA
      1 x 5MC63-67001
      • ninja_unmatched
        • Aug 2019
        • 14
        Wait you replaced the mainboard? The error you are getting involves an issue with the scanner. You should be starting with any related to that.
        Check the scanner cables.
        The scanner itself. Usually the scanners have their own board that can be changed.
        • ninja_unmatched
          • Aug 2019
          • 14
          The error may simply be a bad PCIe cable.
