Pagewide P77940DNS error 61.D3.5C
  • hellcat
    • Jan 2012
    • 124
    Having an issue where we are getting the message 61.D3.5C Airflow assembly Failed - Insufficient AC Power
    Machine still runs fine it just slows down the speed because the airflow blower isn't working.
    I have tested the blower and it runs fine, voltages all check out fine. I changed out the whole airflow assembly and cable assembly and still have the error.
    I am shooting for either the J7Z09-67940 Main Power Supply or the Formatter Board, But I can't decide which one I should go for first.
    Anyone out there had this issue before?
  • ninja_unmatched
    • Aug 2019
    • 14
    Re: Pagewide P77940DNS error 61.D3.5C
    Did you update the firmware? If not try that first...
    Sent from my SM-N986U using Tapatalk
