Riso com colour fw5230
  • wesdog
    • Oct 2010
    • 10
  • MarcoKyo
    • Nov 2019
    • 9
    Re: Riso com colour fw5230
    Hello,
    Have you made a firmware upgrade? The last version is 4.11.001.
    If after that there is no change, replace hdd.
    You can use a ssd and atttempt to copy de hdd with a cluster to cluster hdd copier. If the copy don't work (hdd too much faulty), you can copy one from new machine (don't start it!! also the sn will be written to the disk). Otherwise you have to order a new one from Riso (very expensive for an old generation of hdd).
    Good luck with those buggly devices.
