exit unit missing? or detected open?
Machine was moved and now has a 333 code. It was picked up using the op panel as 1 of the locations to grab it.
Tried a switch scan and the switches wouldn't change. It said L for open when we did that. Pushed it and closed it no change.
Something else that was an issue. There was a grounding cable(?) that was loose and not connected. Wondered if something happened to the board when it was turned on like that.
