Deep blacks in color prints
  • mikrev
    • Feb 2023
    • 16
    In my university, there are a number of color and bw laser printers of various manufacturers. I notice that the blacks of the monochrome printers are always deeper than than the blacks of the color printers. Until now, I have assumed that it is not to overwhelm the colors in the case of a photographic print. I'm interested in buying a color laser printer if I can set it up to print with deep blacks.
    To solve this problem, can you say whether it's a case of changing the toner of the cartridge to one that is darker, or are other factors more important?
  • Gift
    • Mar 2011
    • 2459
    Re: Deep blacks in color prints
    First of all you should use color copy paper that has a very smooth/even surface compared to standarf office paper types for daily use.
    Modern laser printers usually use less toner to reduce the energy consumption for the fuser process. There might be differences between vendors but I'd say this affects all "up to date" model.
    Production Printing is an exception but these are very large and expensive printers.
    There are no "darker" toners - but you some coor MFPs do pretty good blacks, sometimes involving using CMY+K (all colors).
    I'd try and find a dealer that might help you with test prints with your files you can check out.
    • mikrev
      • Feb 2023
      • 16
      Thanks. Do you know of any names of color laser printers that do good blacks that I could use for a starting point?
      • moaazz
        • Feb 2023
        • 1
        تفتيح وتبييض البشرة
        طرق تفتيح وتبييض البشرة
        البشرة هي أكثر المجالات التي يحتاج الإنسان إلى رعاية وحماية بشكل دائم، لذلك يجب علينا تعلم طرق التفتيح والتبييض لمحافظة على صحة ونضارة البشرة. يمكنك الحصول على النتائج المطلوبة من خلال التطبيق المناسب للطرق الآتية.
        روتين تفتيح وتبييض البشره النهاري
        يمكن اتباع الخطوات التالية لتفتيح وتبييض البشرة خلال النهار:
        1- تنظيف البشرة: يجب غسل الوجه بلطف باستخدام منظف ملائم لنوع البشرة.
        2- استخدام التونر: يستخدم التونر لتنظيف الوجه بعمق وتنشيط الدورة الدموية للبشرة.
        3- استخدام اللوشن المناسب: يمكن استخدام لوشن تفتيح البشرة أقوى لوشن لتفتيح البشرة الذي يحتوي على مكونات طبيعية واصلية.
        4- وضع كريم النهار: أفضل كريم لتفتيح البشرة يجب وضع كريم النهار الملائم لنوع البشرة والذي يحتوي على مكونات مثل حمض الهيالورونيك ومستخلصات النباتات التي تفتح البشرة.
        5- استخدام واقي الشمس: يجب استخدام واقي الشمس بعامل حماية لا يقل عن 30 لحماية البشرة من أشعة الشمس الضارة.
        6- الحفاظ على نظام غذائي صحي: أقوى يجب تناول الأطعمة الصحية التي تحتوي على فيتامينات ومعادن تعمل على تفتيح وتبييض البشرة، مثل الفواكه والخضروات والبروتينات.
        7- الحفاظ على ترطيب البشرة جيدا.
        روتين تفتيح وتبييض البشرة الليلي
        يوجد العديد من الروتينات الليلية التي تساعد على تفتيح وتبييض البشرة. أقوى منتجات العناية بالوجه ومن أهم هذه الروتينات:
        1- تنظيف البشرة: يجب تنظيف البشرة جيدًا قبل النوم باستخدام منظف مناسب لنوع البشرة، حيث يساعد ذلك على إزالة الأوساخ والشوائب التي تتراكم على البشرة طوال اليوم.
        2- استخدام مقشر البشرة: يمكن استخدام مقشر البشرة لإزالة الخلايا الميتة والشوائب التي لا تزال عالقة على البشرة.
        3- استخدام مصل الفيتامين سي: يساعد مصل الفيتامين سي على تفتيح وتبييض البشرة، كما يحتوي على مضادات الأكسدة التي تحمي البشرة من التلف.
        4- استخدام كريم تبييض البشرة: يمكن استخدام كريم تبييض البشرة الذي يحتوي على المواد الطبيعية مثل الألوفيرا والليمون والبابونج، حيث تعمل هذه المواد على تفتيح وتبييض البشرة.
        5- تطبيق كريم الليل
        روتين العناية بالمنطقة الحساسة للبنات
        للحفاظ على نظافة المنطقة الحساسية يجب اتباع الخطوات الاتية:
        1- قومي بغسل المنطقة الحساسية بالماء الدافئ ثم جففيها جيدا.
        2- قومي بارتداء الملابس المصنوعة من القطن وتجنبي الملابس الصناعيه المصنوعه من البولي أستر او النايلون لانها تسبب تهيج للجلد واحتكاك مما يؤدي الي الغمقان.
        3- قومي بغسل الملابس الداخليه بالماء الدافئ واحرصي علي تنظيفها جيدا.
        4- قومي بتخفيف المنطقة جيدا بعد استخدام الحمام وهذا من العادات المهمة جيدا لتجنب تكون البكتيريا.
        5- قومي بتبديل الملابس الداخلية مرة الي مرتين يوميا.
        6- اشربي كميات كافية من الماء للحفاظ علي الرطوبة في الجسم.
        7- احرصي علي ازالة شعر المنطقة بالطرق المعروفة.
        8- قومي بعمل تقشير لهذه المنطقة مره اسبوعيا.
        نصائح للحفاظ على نظافة المنطقة الحساسة
        بعدما بينا نقاط روتين العناية بالمنطقة الحساسة للبنات أفضل منتجات العناية والتجميل بالعالم هناك عدة نصائح يجب اتباعها:
        1- عند شراء ملابس داخلية جديدة يجب غسلها جيدا قبل ارتدائها.
        2- تجنبي استخدام منظف الملابس الذي يحتوي علي المعطرات.
        3- تجنبي احتكاك النطقة الحساسة لانه يؤدي الي الغمقان.
        4- تجنبي استخدام الغسولات المحتوية علي المعطرات.
          • 37447
          5- تطبيق كريم الليل
          This is a Printer/Copier forum. Take you skin care advice and shove it up your ass.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Regardless of brand, as already mentioned, “rich blacks “ are composed by adding C, M and Y to the K component.
            For instance the CMYK mix would be “15C, 15M, 15Y, 100K”.
            The percentage of CMY can be varied, but all be equal to each other, and K should always be at 100%.
            This will be much easier to achieve if the application supports CMYK, and not just RGB, as most Microsoft apps do.
              • 37447
              I would start with any Production Color machine such as the Ricoh Pro C5300s.
