KIP 3000 IPS (865 style)
  • mascan42
    • Oct 2008
    • 484
    I just had the motherboard on a KIP 3000's IPS die on me (the old 865 style in the white case). From what I understand, the IPS can either be replaced entirely, or swap the interface card into the new one. Unfortunately, KIP changed the style of IF card during production, and the old board can't be put in the newer IPS. The tech bulletin tells me this much, but it doesn't say how to tell the difference between the two styles of IF card. All it says is the newer one is RoHS-compliant, and the older one isn't. Is there some way to visually tell the difference?
