anyone know what the C of 34 code is on the Imagistics cm2020?
Thanks!
Copy Dawg,
"Yellow Toner density that is 3% or more lower than the target level, detected 10 consecutive times while the developer unit is energized during a print cycle, ATVD, or image stabilization sequence"
Right from the book. Perhaps the Y toner level detection 'window' is dusted with toner and it is trying to add from an empty cartridge. Toner cartridge shutter not opening when installed. Broken toner hopper gear. Defective Y imaging unit. Try running a yellow test pattern and see how the density appears, and think simple first!
Best of luck
Regards,
dcopylady
