Oki es3640 c9600 cu firmware
  • beeptac
    • May 2009
    • 10
    Hello mate,
    i look for the CU firmware for oki es3640 and c9600 someone can indicate to me where to find them?
    this printer it has on the main card a rom that creed contains firmware is programmable or it must be replaced?
    i find the firmware for phaser 7400 (same printer) but not for oki!
    thanks in advance
  • Eric1968
    • 2458
    Why do you want to upgrade?
    • beeptac
      • May 2009
      • 10
      i look for the conversion of my c9600 in es3640 for use consumable es3640 less expensive!
      the machine is the same one, changes only the firmware, but creed that is in the ROM A to with to the postscript.....
      you can confirm it?
      • Eric1968
        • 2458
        That's not possible. Sorry. You can not change a C9600 in an ES3640 just by changing a few parts or reload firmware.
        • beeptac
          • May 2009
          • 10
          why not? i'm read the parts manual (same of c9600 and es3640) and not there are differences in the parts unless for the ROM A!
          • Eric1968
            • 2458
            The RFID-chips on the toners, and the drums are different and I think there are more differences than ordinary techs like us know about. It can not be that easy just to change a few parts.
            • beeptac
              • May 2009
              • 10
              the rfid chips are the same but the ID-information inside is different
              the drums are the same only little mechanical difference...
              however it is possible to upgrade the firmware from software?
              • Eric1968
                • 2458
                I took a look on the Oki FTP-site but only found firmware for the "non-ES-series" (C9600/C9800/C9650/C9850).
                • beeptac
                  • May 2009
                  • 10
                  good morning, Eric
                  thank you for your collaboration, you have found the CU or PU firmware or both?
                  this is my configuration:
                  i think that CU firmware is in the ROM A, ref 48-50
                  • Eric1968
                    • 2458
                    I've found the PU-firmware (V3.00). The CU-firmware is on ROM-A. Don't know what OWF or HMY means.
                    • beeptac
                      • May 2009
                      • 10
                      Thank you Eric, for your interest
                      the mainboard has also a flash rom of 16mb on board perhaps the firmware/setting is resident them.
                      nobody other user has information?
                      • Eric1968
                        • 2458
                        Oki is (in Holland) normally very open when you ask for specific information, but some things are just too sensitive to release. When you know how to convert a normal machine into an ES-machine, they're in serious trouble.
                        • beeptac
                          • May 2009
                          • 10
                          hi,
                          it seems that printing uses the language PJL in order to make upgrade of firmware, this is an example of the PU 3.0...
                          start of file
                          .......cutcutcut
                          end of file
                          I have read also this document for c5100 but the concept does not change...
                          someone knows language PJL for oki, seems that with it the ROM Flash can be written, can even also be read it
                          • COSTALONES
                            oKI C9650 FIRMWARE
                            Hi, I need to re install the firmware of my oki 9650.
                            Where can I get the files and the instructions.
                            Thank in advance
                            • Eric1968
                              • 2458
                              You need to have an account for the Oki FTP-site.
