OKI C5450 drum missing
  • Prodigal Son
    • Mar 2009
    • 161
    Hi everyone,
    I've got a C5450 in for service that shows 'Error 341 - Magenta Drum Missing'. I've replaced the drum, and checked the obvious like lose cables, connectors etc but I can't see anything that would explain it. I've desperatly googled for a service manual, but the only one I can find says nothing else than 'Yes, this error exists'...
    Does anyone have a real service manual for the 5400-series? Or better yet, does anyone know what the problem is?
    Peace sells, but who's buying?
  • PinevskiS
    • Jul 2009
    • 284
    HI.
    I have this problem whit oki c 5450.You must to check contact on DRUM UNIT with board ,mabye the contact (who similar on spring is broken ) and DRUM UNIT don't have contact with board.
    • Prodigal Son
      • Mar 2009
      • 161
      Thanks for your reply!
      Yes, I did check it, where it connects to the left side board. The drum connectors have spring-like arms that connects the drum connectors to the board, and I cleaned those surfaces. Unfortunally I don't have the proper gear for measuring the components, but that could be one solution.
      Have you solved your problem?
      • PinevskiS
        • Jul 2009
        • 284
        Yes i solved the problem check spring who hatch on board contact
        • PinevskiS
          • Jul 2009
          • 284
          THIS IS MY E-MAIL sasopine@yahoo.com
          • Prodigal Son
            • Mar 2009
            • 161
            Great, thanks a lot!
            I solved my problem yesterday too. I had another OKI printer, a C3200, that I could use for spare parts. I changed over the "drum connector card" (for lack of a better word), the card on the left side of the printer. That alone solved the problem, so obviously there's a damaged component there somewhere. I'll try and figure out which one it is and replace it.
