OCE FX 3000
  • HOLZ
    • Sep 2009
    • 10
    OCE FX 3000
    PLEASE HELP WE HAVE AN OCE FX 3000 THAT WONT COPY OR SEND A FAX CONFIRMATION. IT HAS BEEN IMPOSSIBLE TO FIND ANY INFO ON THIS THING. THANKS IN ADVANCE FOR YOUR ASSISTANCE....
    DILLIGAF
  • VThideaway
    pdf
    all docs are at oceusa.com / desktop / fx3000 / docs and drivers ps it is the menu screen
    • kronical
      Kronic Copier Ninja
      • Nov 2009
      • 230
      Can you make any photocopies at all? Are you just having trouble setting up fax reports? Any error messages?
      You can contact the Oce support number that accompanied the machine to have a service technician help you with this issue, if it is under a maintenance agreement. If not, you will be charged for a service visit. I can help you through here as best as I can.
      • HOLZ
        • Sep 2009
        • 10
        I appreciate the help and info greatly!!! We finally got it to copy still no confirmation report.
        DILLIGAF
        • kronical
          Kronic Copier Ninja
          • Nov 2009
          • 230
          Menu, 3, 4, 1 - Job Status Report
          4 options, as listed
          Incomplete - report prints on incomplete transmissions only
          Inc+Image - report prints on incomplete transmissions with image of first page on report
          All - report prints on all transmissions
          All+Image - prints report on all transmissions with image of first page on report.
          • VThideaway
            confirmation
            I told ya where manuals are. It is simple. Press menu press #3 or scroll down to 'fax", press #4 or scroll to "set up report" than pick your choice. It is a nice little Brother mach I got a Fx2700 its the same thing.
            • kronical
              Kronic Copier Ninja
              • Nov 2009
              • 230
              Very true, solid machines. A common problem has arose in my territory and I have confirmed it has been encountered in our other territories as well, the FX3000 will get a nasty grinding/clunking sound from the paper tray when trying to copy/print. Pull the tray and check the gears on the left side for damage, if ok, readjust the rear paper guide and back it off the stack of paper 1 notch. You should be able to turn the gear by hand while loaded with paper, lifting the stack. If you can't turn it by hand, then back it off. If the gear is damaged, contact Oce Service for replacement.
              • VThideaway
                yes call us up
                it is common, little bit of pain getting those little gears out also those fuser gears go too.
