Reset For Transfer Belt On Oki 3200
  • scanrail
    • 17
    Hi,
    Can anyone help with this?
    Message on Oki printer 3200...replace transfer belt. Is there a reset or an easy way to get around the problem without replacing the transport belt?
    Thanks.
  • travi
    • Jan 2008
    • 129
    The only way to reset OKI counters is to replace the item that it is calling for. OKI hides a low amprage fuse in the unit that blows when installed and resets the counter.
    • scanrail
      • 17
      Hi Travi,
      Thanks for that. I have come accross this before with other manufacturers but normally there is a reset rather than having to install new bits housing a resistor/fuse that blows when powered up. The signal sent to tell the printer must be send-able through some other means...maybe not? Anyone any idea on price and availability/dealers etc?
      Many thanks.
      • travi
        • Jan 2008
        • 129
        The OKI Supply number is 42158711 If east of the mississippi try www.azerty.com or west try www.icg.com.
        • scanrail
          • 17
          Thanks Travi,
          I'm a long way form the above but appreciate the supply number, many thanks.
