Oki C3300 all indicator lights on solid
  • D Colour
    • Oct 2008
    • 216
    Hi
    Was wondering if anyone knows how to reset this machine?
    When the machine is turned on, all 3 indicator lights come on and stay on. The fan starts and stays on.
    Oki helpdesk told me to install the status monitor and connect via usb, done this and it tells me to power on the printer and connect up the usb cable. They reckon it could be the main board at fault.
    Any suggestions most welcome!
    James
    Everything that has a beginning, has an end.....
  • Eric1968
    • 2458
    The service manual says that the printer is in the process of shutting down for some reason. When the shutdown process is complete, the LED's should go off. When they stay on the most probable cause is a defective engine board. I don't think you can access the printer with the status monitor, because the printer is already off-line.
    • jonbonse
      • Jun 2009
      • 737
      Re: Oki C3300 all indicator lights on solid
      Hi
      Could you let me know what it means if just the warning LED is on solid and the other 2 LED's off. . . ??
      Many thanks
      • Eric1968
        • 2458
        Could be a lot of things. Install the Status Monitor if the printer is on USB, or browse to the machine's webinterface (using the IP-adress).
        • jonbonse
          • Jun 2009
          • 737
          Thanks!
          I will do and update you . . .
          I dont suppose you have the SM you could email?
          Regards
