I'm getting error code C-2807 and C-2804 on Develop Ineo 600. Pls kindly let me know what does this codes mean. I would appreciate if you can provide me with a list of error codes and service mode. Thanks.
Develop Ineo 600
Tags: 280, 2807, 600, code, codes, control panel, develop, error, error code, mode, service, touch screen
DEVELOP is a Konica Minolta brand so you will find you get responses if you post threads in the KM section.
Remove the drum and clean the 2 sensors which look at the drum. This should clear both error codes.
Service mode is the same as Konica Minolta. On the control panel press the UTILITY/COUNTER hard key, press the METER COUNT on the touch screen, press DETAILS on the touch screen.
Now press these hard keys in sequence STOP 0 0 STOP 0 1Comment
Thanks for help. The errors were cleared.Comment
