problem with nashuatec - 1505 error sc 320
  • tariq65
    • Jun 2010
    • 84
    hello
    every one i am faceing the problem with nashuatec-1505 error sc-320 how can do
    plzs.help me thanks.
  • RebelPhoenix
    • Oct 2008
    • 138
    Hello dear friend.
    I think you don't use the machine. When will you turn on the machine after machine show this sc code.
    You must defective polygon mirror motor, I hope polygon mirror motor is not work.
    • tariq65
      • Jun 2010
      • 84
      sir,
      thank to repaly i am a local techain faceing the problem When i turn on the mach after machine show this sc code.320
      plz give ida whait can do.
      • RebelPhoenix
        • Oct 2008
        • 138
        You must see the polygon motor working, open the laser unit cover, and turn on the machine, Look at the polygon mirror motor if poygon mirror motor isn't turn you must change the polygon mirror motor.
