Nashuatec D618 ERROR 901
  • samsogoye
    • Aug 2010
    • 30
    [Error Code] Nashuatec D618 ERROR 901
    I need your help please, When I turn on the machine within two second it bring function problem error no: 901 so It does not rotate any thing(initialize the system)
    I need you help.
    Sam From Tanzania E.Afrika
  • samsogoye
    • Aug 2010
    • 30
    Someone to help me please.
    • RebelPhoenix
      • 138
      I want to help you but machines model isn't true. This machine is Nashuatec DSM618 or D418 ? Please check and says it.
      • samsogoye
        • Aug 2010
        • 30
        its DSM 618
        • RebelPhoenix
          • 138
          Hi dear friend,
          I know this sc code detail and I checked again to make sure,
          SC-901
          You must check the mechanical counter installed, or work,
          You must check the BICU (Base control unit = Mainboard)
          I see this trouble two years ago, turn on machine and after machine is ready, I start a copy machine give the copy after show sc-901,
          Turn of turn on again, again,
          After I change the mechanical counter with a new, but machine is show SC-901,
          I've done a lot of trial, it's time BICU can be broken.
          • samsogoye
            • Aug 2010
            • 30
            Thankyou let me start by mechanical counter..then BICU.
