oki c5850 need firmware
  • spiros
    replied
    Re: oki c5850 need firmware
    Problem solved! I upload new firmware..!
  • Eric1968
    replied
    [QUOTE=spiros;375618]
    Originally posted by Eric1968
    You've lost the network firmware? If the network menu isn't visible, it means that the network part of the controller is defective. Can only be solved by replacing the controller board.[/Q
    sorry my fault... i lost the network menu,(Unfortunelly I click flash format in sm. Now I don't have network settings in menu.)
    Every time I wonder why people do a flash format, or perform memory clear without a backup. The service manual clearly states : "Do not use this in the field!"
  • spiros
    replied
    [QUOTE=Eric1968;375600]You've lost the network firmware? If the network menu isn't visible, it means that the network part of the controller is defective. Can only be solved by replacing the controller board.[/Q
  • Eric1968
    replied
    Originally posted by spiros
    please can enyone send me this file for oki c5650 ( i have lost the network filmware) PJL_p0401_w0401_cA100_aA102.bin
  • JustManuals
    replied
    See the post above yours.
  • spiros
    replied
  • JustManuals
    replied
    Originally posted by OddPaul
    Hi
    Can someone send me the PJL_p0401_w0401_cA100_aA102.bin file to nobuserigame@gmail.com.
    Thanks very much.
    No. This is not a site for 1-hit wonders to come and get software, never to return till they need something again.
  • Eric1968
    replied
    Hi
    Thanks very much.
    After 1 post on this forum? Don't think so...
  • OddPaul
    Guest replied
    Hi
    Thanks very much.
  • bpmagister
    Guest replied
    Hi all,
    My problem has been solved thanks to Sunshine.
    If anyone has the same problem only need Hostif.exe program and firmware to send to the printer by following these steps:
    1. Connect the printer via USB and run the program HostIF.exe
    2. Select Connection> If Connection> USB, the printer name Should Appear (C5600/C5800)
    3. Select File Management> Block Transmission> FileSelection and load PJL_p0801_w0801_cA201_aA201.bin (or the name of your firmware file)
    4. Select transmission and the file will be sent to the printer.
    5. LCD will display "Data Arrive" then "FW Loading". Eventually The LCD will return to "On_Line".
    6. Power cycle the printer.
  • Sunshine
    Guest replied
    Originally posted by bpmagister
    Hi all,
    Can anyone send me the firmware PJL_p0401_w0401_cA100_aA102.bin and the application to update the firmware in Oki C5650?
    My email is: djpol94@gmail.com
    Thanks very much
    I've pm'd you what I have.
  • bpmagister
    Guest replied
    Hi all,
    Thanks very much
  • bpmagister
    Guest replied
    Hi all,
    Thanks very much
  • Sunshine
    Guest replied
    I have just emailed both of you with the files, if you've not received them please check your spam folders for hidden features at hot mail
    Hope the files can help you out!
  • FMAC9
    Guest replied
    Can you send me the file hostif.exe
    Thank You..
    fmac9@hotmail.com
