Hp CM4730 - Jamming when Duplexing - Require technical bulletin?
  • SGT_Snacks-64
    • Oct 2007
    • 157
    [Jamming] Hp CM4730 - Jamming when Duplexing - Require technical bulletin?
    Hi,
    I have recently been working on this model of machine for the past month or so.
    I have found one problem within the Transfer unit of this machine which I feel should have some sort of modification bulletin for it. However I can't seem to find any information on the matter.
    Symptom: Duplex LATE Jam. Paper stops on rear of Transfer unit passing 1 set of duplex feed rollers.
    Cause: Gear within Transfer Unit which drives the rear paper path plate detatches from the shaft.
    Resolution: For the time being I've been pushing the gear back along the shaft. However this isn't a permanent fix and I feel it should have some sort of clip on the end to hold the gear in place.
    There's no additional shaft after the gear so this isn't possible. I was wondering if any other field/non-field Engineers have experienced this issue and if there's any kind of fix to prevent the problem from occuring again.
    I can't post images at the moment but I will post some examples of what I'm seeing tonight. Just to give you a better idea of what the problem is.
    Thank you for your time.
    SNX
    Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
    Asus P5E-VM HDMI
    4GB (2x 2GB) Corsair XMS Xpert II RAM
    ATi Radeon 4870 512MB GFX Card
    2x 74GB WD Raptor Sata HDD (RAID 0)
    500GB Seagate Barracuda Sata II HDD
    500GB Hitachi Sata II HDD
    600W500att OCZ PSU
    -TOTAL HDD SPACE 1148GB-
  • prntrfxr
    • 1622
    I am responding due to the fact you sent me a notification on my profile and no one has answered this. I don't have any information regarding this issue and as of yet have not encountered it. I will let you know if and when I do. Usually the resolution for duplex issues is one of three parts. P/U Asm (where turn takes place), transfer belt, or fuser. Usually replacing one of the three resolves duplex issues.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
